MD6A Replacement Oil Filter - SailNet Community
Blogs
Old 09-19-2007
scurvy's Avatar
scurvy is on a distinguished road
Send a message via AIM to scurvy
Might any of you brave MD6A owners out there know of a FRAM, AC DELCO, or something similar (and readily available) to replace the oil filter on the MD6A?
I am heading up to the boat this weekend, and think I may do an oil change and filter change, so was wondering if I might be able to pick up an automotive replacement part? Any suggestions?
Thanks
Chris
Old 09-19-2007
hoppy is on a distinguished road
Oil Filter
Wix makes a replacement for just about everything. My MD7A uses a
Wix #51335 oil filter. Wix also makes a replacement diesel fuel filter.
Believe you can get correct filter #'s on Wix web site.
Hoppy
Old 09-20-2007
groundhog is on a distinguished road
be careful, the wix that was my fuel filter is a 10 micron. Volvo specs something like a 3 micron fuel filter.
Wix may have a finer filter. don't know.
Old 09-20-2007
scurvy's Avatar
Thanks Hoppy and Groundhog!
Hey Groundhog, this is for my Vega. Might have found an AC Delco replacement for it as well, but will need to do a little more research. Will check out the Wix site and see what I come up with. Some have said that the 10 micron is just too small and can sometimes do more harm than good.
Chris
Old 09-20-2007
ntheyer is on a distinguished road
I use a 1307 from NAPA for my MD11C.
Not sure if that will help you though!
Perhaps it might help you cross reference something.
Old 09-20-2007
scurvy's Avatar
Not sure if that will help you though! Perhaps it might help you cross reference something.
Will look that up. There is a NAPA a few miles away and that would be very handy. I will stop by there and see if they can cross reference. I have always found it (in shops such as VIP, NAPA, etc..) that it is best to have the information ahead of time, as they tend to look at you cross-eyed if you have to ask for help finding something...
Thanks for the info
Chris
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 09:55 AM
Where in Carmen Sandiego is the oil filter? jaschrumpf Atomic 4 16 07-20-2009 10:48 PM
Ranger 33 FWC and oil filter gunnyret92 Gear & Maintenance 1 02-28-2007 04:04 PM
"Modified" Fram Oil Filter pma_foyl Gear & Maintenance 1 11-30-2004 11:01 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
