09-22-2007
Last Grumpy Old Sailor
Originally Posted by gc1111
I guess with a gas engine you have to be a lot more careful with the fuel coming out.
Yeah.
For a pleasure boat with the electric pump (if any) turned off, melting the plastic will most likely just shut down the engine - especially on a diesel. So in that case the danger is much less, but still there.
I have an A4. Unless the PO replaced it (didn't mention he did), it still has a mechanical fuel pump. Tho I hardly see where that makes much difference.
So the up-shot is I can either stay with my current filter/separator, where I can't see what's going on inside, or I can replace it with a new Racor, where I won't be able to see what's going on inside. (Dear Racor: How about a metal body with a glass bowl on the bottom?) As long as replacement cartridges are available for this old Fram I have, I guess I'll just stick with it.
mwrohde or gc1111,
Either one of you wouldn't happen to have any notes or documentation around on the part number for the replacement filter cartridge, would you?
Thanks,
Jim
s/v Abracadabra
1976 Pearson P30
