  #21 (permalink)
Old 09-21-2007
tjvanginkel is on a distinguished road
As I understand it here in BC there are not yet requirements for pleasure craft regarding overboard discharge except in Marine parks... Not to sure about this. I also understand that we cannot enter Washington state with having a holding tank. Is this true? If it is would a composting toilet meet their requirements? And is there any one out there that has used one on board? If so what and how much and are you happy with it?
I hadn't heard of the airhead until now. The one I had been looking at is from !you know what.sun-mar.you know what! and certainly seems much bulkier... 23" deep. I also like the solar fan option on the air head. My aunt uses a composting toilet at her recreational cabin and is very satisfied with that but it is definately big. However, they have found, if they don't pee in it so much things work much better and it doesn't smell. Seems like you could easily work around that on a boat....
  #22 (permalink)
Old 09-22-2007
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
some things to think about
I researched the composting toilet a few years back.
The electrical consumption on the model I looked at was pretty minimal - just
a circulating fan,
But what stopped me is that these things need an "exposure" on more or less a daily basis, in order to keep the enzyme farm from dying out. As pretty much a weekend sailor, that killed it for me. But for liveaboard use they look
to be a good fit.
  #23 (permalink)
Old 09-22-2007
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
to be a good fit.
The airhead site specifically talks to "weekend" use.
http://www.airheadtoilet.com/howitworks.html
Their use of it seems to be a lot less than I think I/we would use it.
Maybe I am too full of it!
Then there is all that paper supply.
And they don't explain exactly how you "flush" it.
And what about "the squirts"?
And the liquid dumping part for a beer drinker might be ummm.........well.........forget it.
  #24 (permalink)
Old 09-23-2007
Here .. Pull this
Sailormann will become famous soon enough
Well...here are the Canadian Regulations that apply on the Great Lakes:
Environmental Protection Act
R.R.O. 1990, REGULATION 343
DISCHARGE OF SEWAGE FROM PLEASURE BOATS
Consolidation Period: From February 12, 2007 to the e-Laws currency date.
Last amendment: O.Reg. 35/07.
This is the English version of a bilingual regulation.
1. In this Regulation,
"pleasure boat" means a boat used primarily for the carriage of a person or persons for pleasure, whether on charter or not, and whether for compensation or not, and includes a boat used on water for living purposes; ("bateau de plaisance")
"sewage" means organic and inorganic waste, and includes fuel, lubricants, litter, paper, plastics, glass, metal, containers, bottles, crockery, rags, junk or similar refuse or garbage, and human excrement, but does not include,
(a) liquid wastes, free of solids, from water used in a pleasure boat for household purposes, or
(b) exhaust wastes, cooling water and bilge water from a pleasure boat; ("eaux d'égout")
"storage equipment" means equipment of a design and construction suitable for the storage or the incineration and storage of human excrement in a pleasure boat including such equipment that is an integral part of a toilet; ("appareil d'entreposage")
"toilet", in relation to a pleasure boat, means equipment designed or used for defecation or urination by humans. ("cabinet de toilette") R.R.O. 1990, Reg. 343, s. 1.
2. No person shall discharge or deposit, or cause or permit to be discharged or deposited, into any water, sewage from a pleasure boat. R.R.O. 1990, Reg. 343, s. 2.
3. The owner and the operator of every pleasure boat in which a toilet is installed shall ensure that, while the boat is on water,
(a) the boat is equipped with storage equipment; and
(b) such toilet and storage equipment are installed so as to be non-portable. R.R.O. 1990, Reg. 343, s. 3.
4. The owner of a pleasure boat in which a toilet or toilets and storage equipment are installed shall ensure that each toilet and the storage equipment are installed so that,
(a) the toilet and equipment are connected in such a manner that the equipment receives all toilet waste from the toilet;
(b) equipment designed for the storage of human excrement is provided with a deck fitting and such connecting piping as is necessary for the removal of toilet waste by shore-based pumping equipment;
(c) no means of removal of toilet waste is provided other than the means mentioned in clause (b);
(d) equipment designed for the incineration and storage of human excrement is supplied with such electrical current or other source of heat as is necessary to reduce to ash all excrement deposited therein; and
(e) all parts of the system for removal of toilet waste are congruent with one another and the boat. R.R.O. 1990, Reg. 343, s. 4.
This is R.R.O. 1990, Reg. 343, s. 3 referenced above:
Note that the regulation states that the toilet needs to be INSTALLED so as to be non-portable WHILE THE BOAT IS ON THE WATER
This means that while your boat is floating your portable toilet needs to be held in place with a secure system that would not allow it to be moved. i.e.: it is not acceptable to use something that can be passed from cabin to cockpit, or moved around the cabin.
The unit needs to be equipped with a vent and pumpout fitting, and you need to connect this to a pumpout fitting on the deck.
The Thetford MSD Sanipotties are definitely legal, as are some others:
SaniPottie MSD marine toilet.
3.0-gallon (11.4-liter) holding tank capacity.
Permits overboard discharge, dockside pumpout,discharge into remote holding tank. Includes stainless steel hold-down brackets.
Vacuflush toilet, head. toilets Myblueheaven General Discussion (sailing related) 12 01-25-2012 11:39 PM
Air Head Composting Toilet arf145 Gear & Maintenance 20 02-07-2010 09:37 AM
Compost Toilets - Changing The Head Cephee Gear & Maintenance 1 07-30-2007 07:03 AM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 06:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 03:55 AM
