Old 09-20-2007
anneellen is on a distinguished road
Angry Garmin GPS problem
I have a 6 year old Garmin 76Cmap GPS. Suddenly the screen went blank and no buttons affect it. It was wired to the boat; I have taken it off and put new batteries in. The screen is still blank as it is when turned off. The power button has not effect. Has anyone had this experience? Richard
Old 09-20-2007
tomaz_423's Avatar
tomaz_423 will become famous soon enough
Not on Garmin, but on a mobile phone.
I think some electronics have build in timer and is programmed to fail when the new model comes on the market (and cheap stuff fails random).
Edit: Once I changed to night mode by accident and I thought the screen is blank - You problem probably is not just that, but let us hope it is.
Beneteau Oceanis 473
preparing to sail away
Old 09-20-2007
If you hold the unit at an angle to the light, can you see anything on the screen? If so, then the backlight has probably died... if not, then something blew in the unit. I don't remember if the unit has an internal fuse. I'd check on my Garmin 76CS, but it's on the boat.
Old 09-21-2007
Thanks for the replies. I let the unit sit around for a couple days and tried it again; it fired right up. Have no idea why. Maybe the new batteries needed time to have an effect.
Old 09-21-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
I've seen that happen before when I was flying. Now that is scary.. What hapened is the instrument had collected humidity from a bad gasket and a windscreen leak perfectly placed.
I'd give it a good internal cleaning with a good near-anhydrous isoprophyl alcohol. (meaning no water) At least shoot for a nice bottle of 97%... then leave it sit in the warm dry air of your home for a few days and reassemble. You shold be able to get 97% from wal-mart (ugh I know) or Target for about 80 cents. I don't think 100% is practical because it sucks the water out of the air and IIRC it is only allowed in labs... I forget.
If you really want to dry it out, Do what I did with a cell phone I dropped in the drink - Give it the ETOH cleaning, then put the pieces in three gallon sized plastic baggies with a few packets of silica or whatever it was called (those pellet packets that suck the water out of the air) and let it sit in a warm place like on top of your PC's case for a few days.
Remove, reassemble, you're in like flynn.
Robert
I reject your reality and substitute my own.
Handheld GPS Overview Tom Wood Seamanship Articles 0 05-31-2001 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
