- Quick Menu
09-25-2007
Here .. Pull this
I'll make it easy for you Jim. Take a walk around the club/marina and look at the sheeting systems on other boats around the same size as yours. Then go the boat store and buy what they have.
Don't try to save money by buying something more economical or slightly smaller or not quite as well made. This is a piece of gear that you buy once every fifteen or twenty years. Get a good one. Get a big one.
If you can only afford to buy the top half then buy that now and wait until spring to get the other part.
Use 1/2 inch line.
Don't assume that you are going to be able to avoid 30 or 35 knot gusts, because they come up fast and are gone before you can get anywhere near the reefing lines.
After you've sailed the boat reefed a couple of times, you're not going to want to do it unless it's absolutely necessary, because the sail shape is bad, and it flaps and makes noise and is just butt ugly to look at. So you're going to do what most of us do and get out there, get hit by a couple of gusts and then MAYBE reef, or else just let the sheet fly for a few seconds until it blows through.
Most of the time, you reef because you are out there in the middle of something that's uncomfortable or dangerous and you have to keep going forward, but it is rare to see anyone leaving the slip with their sails in bondage... (the wife maybe, but not the sails  )
09-25-2007
I just put the harken upwind track/traveler on my 30' Jeanneau ith 160# of main, which will be 190 with a full roach. I currently have the original 4-1 also. may go to a 6-1 or even the 4-1 with smaller 4-1 built in for a 16-1. if only to make it easier for spouse to pull in and use.
I rerigged my boom vang the other day too, went from a 4-1 to a 6-1, boy is that nice when the wind picks up, along with bringing it back to the top cabin with a winch availible too! Hopefully I will not need that.
In the end tho, go bigger, not smaller!
marty
09-25-2007
Originally Posted by KeelHaulin
Jim-
I understand the position you are in. There are plenty of people walking the docks that can give advice; but the bottom line is you need to base your decisions on what you KNOW to be correct.
I haven't been asking "just anybody." The three local people, four, incl. the PO, are all sailors with extensive sailing experience on multiple boats. Three of them, at least, have extensive racing experience. (Not just club racing, either.)
Most people that own a boat; specifically a sailboat are aware that the safety of the crew and guests are ultimately the responsibility of the skipper;...
I'm well-aware of that.
It is a small expense relative to the purchase and long-term mainenance and berthing costs; so it should be a no-brainer (IMHO).
All these "small expenses" are adding up to be one rather large expense. We're being nickel-and-dime'd to death. We started out with a $13k boat. By the time taxes, club/slip/storage fees, new/additional equipment (good GPS, etc.) and needed upgrades/repairs (head rebuild, oil-changing system for the A4, etc.) get done with us, we'll be up to somewhere in the vicinity of $20k. The Admiral is getting twitchy. I don't blame her.
I don't know what the load capacity of your old controls are; if you replace them with 4:1 and low load blocks it seems to me like it would be trading one bad apple for another. If those Schaefer blocks happen to be high load carrying you could be making matters worse.
I don't know, either. I don't know as it's possible to find out. They're original equipment, which means they were put on the boat 31 years ago. I'm not sure it really matters. They were put in in an end-boom sheeting configuration, and we're at 2/3 to 3/4 boom now.
My opinion is based on what the Harken calculator says for 35-45kts. My description of SWL vs. Breaking Load and what it should mean to you ...
35-40 kts! Holy mackerel! If I'm out in 35-40 kts, even if they're just puffs, and I don't have two reefs in, I don't belong in that boat on the water.
The blocks I have on order are good to 19 kts (SWL) and 27 kts (breaking load), with a full main. Now that might be pushing the envelope, assuming we're still running un-reefed in 19 kt winds and we're getting 27 kt gusts. Personally, I rather doubt I'll be sailing in that weatherw/o at least one reef in. (The PO, a very experienced sailor and racer, used to put the 1st reef in at around 20 kts, dropped from the #1 to the #3 at 25 kts, put the 2nd reef in approaching 30 kts, and dropped the #3 at above that, IIRC.)
I appreciate your points, KeelHaulin, really I do. I like to over-design/over-specify, myself. But The Admiral ain't goin' for it this time and believe the Lewmar blocks we have on order will be up to the task.
Jim
09-25-2007
You know, that's such a simple idea I completely missed it
It's not so much a question of "saving money," as not spending any more than necessary. And the Lewmar racing blocks we have on order are well-made, trust me  .
After you've sailed the boat reefed a couple of times, you're not going to want to do it unless it's absolutely necessary, ...
See my last reply to KeelHaulin regarding how the PO used to operate the boat.
We did sail her once, already, with a reef in. A reef in and no headsail. Did 7.5 kts in about 15 kts true (according to SailFlow, later on) on a beam reach, at one point.
... it is rare to see anyone leaving the slip with their sails in bondage... (the wife maybe, but not the sails  )
 That time I mentioned above, we left the slip with a reef in.
Reefing's a performance issue, too, as I'm sure you well know. As per the common wisdom: I'd rather shake out a reef I didn't need than have to put one in when I'm finally left with no choice.
Jim
09-25-2007
STARBOARD!!
Double Post...
09-25-2007
STARBOARD!!
Well; let's just say that people who have not "crunched the numbers" are not well enough informed to give you the advice you are looking for. I guess that I have a different perspective than your local sailors because heavy wind is the norm on SF Bay and it's not uncommon to see the racing sailboats heeled to 60 deg, dismastings, catamarans getting flipped, boats in distress, etc. Every weekend in the summer there is some sort of Pan Pan call for a boat that is sinking or a person that has gone overboard it seems. Lots of people are out sailing in boats that are under-equipped or people that are just too confident in their skills. That's why I suggest over-building the running rigging; at least it would minimize that potential for failure/injury.
Welcome to sailboat ownership! Some humorous things I have been told are:
B.O.A.T. - Break Out Another Thousand
A BOAT is a hole in the water that you throw money into.
Owning a sailboat is like taking a shower while ripping up hundred dollar bills.
Just think what it could cost if you have a mainsheet failure and your main, boom, rig get damaged. Hopefully your ins will cover some of it; if they don't require a survey to determine cause.
All of these things point to one thing. Likely undersized, getting old enough to have cracking sheaves; basically in need of replacement. Whoever moved it in 4 feet without re-sizing it really did not know what they were doing. It was designed for end-boom loads; it should be replaced with something that is properly sized.
You'd be amazed at what your boat's hull and standing rig is designed to handle. I think you are a little overwhelmed with the boat and it heeling while she sails in 'moderate' conditions. It takes some getting used to; and someday you may want to sail in heavier conditions with less reefing. Or, I could be totally wrong; your particular boat may have too much mainsail area relative to the Jib and become a handfull when the wind pipes up. I learned to sail on a Columbia 24 and it was great until the wind hit 20 kts and then it was very uncomfortable because the main was way too big; rudder too small.
Way undersized IMHO. You never want to put your rigging in the potential failure zone when sailing under normal/moderate wind conditions. What about the event of a hard gybe? What if you can't get a reef set because the halyard sticks? An unforseen problem can be compounded if something (like your mainsheet rig) physically breaks while you are under full sail.
If it were me I would either mutiny or go AWOL. I don't think Lewmar 50mm blocks are correct for your application (good god man, predicted breaking load at ~25kts??), and I pray for you and all those who sail onboard your boat. Unknowing, self-proclaimed, Admirals who don't make safety conscious decisions should be keel-hauled!
09-25-2007
I like to go out when there's a SCA posted. I was out earlier this year on a day where someone had reported some boats had broken free of their moorings... and was out sailing in that. Didn't see any powerboats that day for some reason.  The gusts were easily up to the mid-30s...
09-25-2007
Here .. Pull this
Gee Sunshine - hate to ruin your day - but a 30 foot boat costs between 40 and 50 K. You can spend it at the front-end or you can spend it over the first two years, but you're going spend it  Perhaps the Admiral can pick up a part-tme job to help out for a while ???
09-25-2007
Sailormann has a very good point... if you bought a boat that needed work, you've saved money on the front end, but it has to be paid in either parts or sweat equity somewhere along the line.
09-26-2007
I gave 'em the numbers. A couple replied that they felt Harken's calculators "over-spec" things. (My words, not theirs.)
I don't believe (the key word here is "believe") that's common, here. I'll have to ask about it. But your point is valid, nonetheless, if for no other reason than we someday plan to cruise with this boat. So what we're experiencing here, or likely to experience here, isn't necessarily what we'll experience elsewhere. Indeed: Even just going across the state, to Lake Michigan, will be quite different. (I understand Lake Michigan can become quite harsh, quite quickly, quite unexpectedly.)
I think that's supposed to be "standing under a cold shower"  . Heard 'em  . Related 'em to The Admiral. She didn't see why these things should be true. She's finding out.
Precisely one of my points, night before last.
Another point I made.
Good argument. I'll keep that one in reserve for the next time  .
I mutinied. I called up and canceled the order late yesterday afternoon. (Made it just in time, too.)
60mm, actually. It's not so much the 60mm, but the SWL and breaking strength.
27 kts, but your point is valid.
Now I just need to decide between the Lewmar 80mm fiddles, the Harken 4:1 solution (57mm dual block, 76mm fiddle), the Harken 6:1 solution, or maybe the Harken 4:1/8:1 self-contained system. (I'd really like to go w/Lewmar, but they don't appear to do anything with a ratchet, other than fiddle blocks.) Decisions, decisions. The lower I go, the faster I can move the boom and the less mainsheet I'll have on the cockpit sole, but the more strength it'll take to use. The higher I go, the slower the boom moves, the more sheet on the cockpit sole, but the more likely The Admiral, and perhaps I, will be able to deal with it. I think a tour of the club's slips is in order, as Sailormann suggested.
To you, KeelHaulin, and the others: Thanks for patiently continuing to beat me up on this issue. Who knows: Perhaps y'all saved our boat--maybe even our lives.
Jim
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
