09-22-2007
I totally agree with the recommendation to haul. If the tube is cracked, then applying epoxy over the crack is only covering the problem. Most tubes that I've seen are comprised of multiple layers of glass; if a leak has occurred, then the tube is compromised. It's not really that bad of a repair except that the shaft needs to be pulled, etc. I agree with the "check the shaft" recommendation too - it's probably bent if this much damage was done. This is too important a job to skimp. Sorry to hear about your problem
Sucking up a line is more common that you think. When I was working in a yard, a powerboat came in with a crushed transom after the owner put the boat into full power after wrapping the line - sucked him right into a piling. I ended up rebuilding the starboard corner of the transom (pretty big job for a 20 yr old)
In another instance, the USS Pinckney (DDG 91) was transiting the Panama Canal during her maiden sailaway and was attempting to tie to a temporary mooring when the Captain observed to the pilot that a line/cable was in the water. The ship sucked an 8' diameter mooring buoy into one of her props before the captain could relieve the pilot. The new prop was destroyed and Pinckney ended up trail shafting all the way to San Diego. I wasn't aboard when this happened - I'd gotten off in Cartagena and met the ship again in Puerto Vallarta (I didn't feel like transiting the canal in the dark again, but this time would have been entertaining!).
Sabre 38 "Victoria"
