Ignition switch stuck in on position. - Page 2 - SailNet Community
post #11 of 16 Old 09-24-2007
HELLO GUYS... this thing is a diesel... there are no points or even an ignition system... it's a diesel...
sailingdog is offline
post #12 of 16 Old 09-24-2007
thinking of this...
JSL3's Avatar
For a temporary fix, try using needle nose pliers to grasp what is left of the key in the switch. You should then be able to turn it off.
The same thing happened to me a few years back. While sailing toward the sea wall just outside of the harbor in Annapolis, the key broke off in the ignition. We dropped the jib and eased the main sheet to reduce speed and luckily was able to start the engine relatively quickly (although the mood was tense at the time) by using some needle nose pliers and grasping the end of the key that was left the cylinder. By digging out some of the plastic part of the slot where the key is inserted we were able to get a bite on the key. We used the “pliers” technique successfully for 2 more starts and stops until we replaced the switch.
~Jim
Ramble On
1986 Pearson 28-2
JSL3 is online now
post #13 of 16 Old 09-24-2007 Thread Starter
Seattle Sailor
Didn't think about an electronic fuel pump - Ill check that. The points and ignition issue is obvious, but I appreciate the comments.
PDean
CS 34
Seattle, WA
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
padean is offline
post #14 of 16 Old 09-24-2007
Here .. Pull this
I have a bilge blower that is wired to the ignition switch on my CS30 - when the key is on the blower is on - might be a good idea to check and see if you have one as well. If so, then just reach inside and loosen one of th ignition wires.
Have you posted this on the CSOA site as well ???
SD: There is nothing wrong with the CANADIAN boat, its the friggin' AMERICAN engine that's deeefective
Sailormann is offline
post #15 of 16 Old 09-24-2007
Boasun's Avatar
Until that start switch key lock is replaced. Disconnect your batteries and carry the battery cable home with you. A cheap form of security.
Boasun is offline
post #16 of 16 Old 09-24-2007
Sailormann-
You must be getting old...took you 11 hours to pickup on that....
Bad Starter? Ignition Switch? theArchitect Gear & Maintenance 16 07-24-2007 11:27 AM
Battery Charger and Selector Switch Position theArchitect Gear & Maintenance 5 05-24-2007 05:00 PM
Lines of Position, Bearings, and Fixes Jim Sexton Seamanship Articles 0 03-23-2004 07:00 PM
Lines of Position, Bearings, and Fixes Jim Sexton Her Sailnet Articles 0 03-23-2004 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
