09-24-2007
If you're using InterProtect, you can layer the barrier coat using the two different colors to control the amount of overlap.
If the hull of your boat is white, use the Grey IP2000 as the base coat... then leave a two-to-three inch band of Grey IP2000 around the boat stand showing when you do the second layer of White IP2000.
Put another layer of Grey IP2000 on, leaving a two-to-three inch layer of White IP2000 showing, and then put another layer of White IP2000, leaving another band of Grey IP2000 showing.
Then move the stands... and then fill in the layered squares...
