Old 09-25-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
Using filler in epoxy
Just wanted to verify that using a filler just thickens the epoxy? Hardener just changes the working time? If you are filling voids from a wet deck would you use a filler?
Old 09-25-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Yes a filler thickens the epoxy. The hardener is the "part 2" of epoxy. There is no epoxy without hardener. Yes it will affect working time, but I would follow the directions. As far as filling in voids in a wet deck, two things come to mind. Is the epoxy just a bandaid ? Will this fix the problem ? Second, how deep are the voids ?
S/V Scheherazade
Old 09-25-2007
johnhalf is on a distinguished road
You are correct, although there are some differences in working time between thickened and unthickened. Check out http://www.westsystem.com/ and go to product information, and then user manual, lots of good info on their web site.
P-26 Sundance
Old 09-25-2007
Jeff_H's Avatar
Super Moderator
The speed of the reaction should be controlled by the type of hardener used (slow or normal) rather than by the amount of hardener. I am a big fan of MAS epoxies for what you are doing since they do not form an amine blush. Often you are recoating or refilling an area and you don't have a way to clean off the amine blush formed on other brands of epoxy. MAS supposedly has less allergens as well.
Old 09-25-2007
IIRC, one other thing nice about the MAS epoxies, is that you can mix the slow and fast hardeners to alter the curing time a bit, which you can't do with the West System normally.
Old 09-25-2007
arbarnhart's Avatar
arbarnhart is on a distinguished road
Really? I have used epoxies from half a dozen different vendors over the years (RAKA was my favorite) and I never encountered that. Sometimes figuring the proportions could make your head hurt, so I would just mix some slow and some fast and then mix the mixes. A few of RAKA's "kits":
http://www.raka.com/EpoxyPricing.html
include a mix of your choice of hardeners. I used RAKA when I built this from scratch:
a few years ago. And yes, that was a lousy lug sail in the picture. I l;ater made a sprit for it.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
Old 09-25-2007
camaraderie's Avatar
moderate?
Thanks for the clarification Andy...for a minute there I thought you'd stolen one of CD's solar panels!! (g)
Old 09-25-2007
arbarnhart's Avatar
It actually sailed okay in light winds,but it had a bad lee helm and would have disappeared over the horizon if I had fallen in. I had a real learning experience about taking shortcuts on that boat. I mixed some fast and slow so I could do 2 strakes in one night. I pushed the time window a little too tight and had Murphy's law kick in and a couple of spring clamps pop off and out of reach while I was alone in the garage. I had to stand and hold the strakes in place at one end for about an hour and a half.
-Andy
Old 09-25-2007
saurav16's Avatar
The void is from wet deck. Ground out the wet core and want to fill with epoxy and will paint later. This is all under stanchions.
Old 09-25-2007
arbarnhart's Avatar
Hopefully you know this, but just in case...
Use slow hardener when filling voids. Fast hardener causes the epoxy to get very hot; hot enough to melt plastic mixing cups (DAMHIKT).
-Andy
Low Maintenance Brightwork: Varnish or Linear Polyurethane over Epoxy? Spencer28 Gear & Maintenance 9 09-14-2011 10:44 AM
What's the best way to epoxy in plywood? duffer1960 Gear & Maintenance 8 05-29-2006 06:34 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Epoxy on Carvel planking crkelly Gear & Maintenance 2 03-10-2001 08:39 AM
Filling Holes with Epoxy Sue & Larry Gear and Maintenance Articles 0 09-25-2000 08:00 PM
