Old 09-27-2007
kavakava is on a distinguished road
Kerosene mixed into diesel fuel?
A local mechanic suggested mixing a few gallons of kerosene into the diesel fuel tank helps the fuel keep better. Anyone heard of this or tried it?
Old 09-27-2007
Yugi's Avatar
Yugi is on a distinguished road
Send a message via AIM to Yugi
I would say it cant hurt. If your in a cold climate you could add up to 50%
My diesel car runs on waste vegatable oil so diesel and Kero are about the same compaired to what I'm blending.
My wife said if i go windsurfing one more time...I'm gonna miss my wife.
Old 09-27-2007
k1vsk will become famous soon enough
There are two grades of diesel, #1 and #2 obviously named by some very imaginative person... Not sure if I have it backward but #1 is diesel and #2 is diesel cut with a percentage of kerosene, the purpose of which is to lower the gel point in extreme cold. One can infer from this that either is acceptable in a diesel engine but age prevents me from remembering at what percentage the mix becomes problemmatic.
I don't undertand how cutting the diesel with kerosene will make it "keep better" other than increase the volatile fraction of the fuel which has no bearing on growth in or degredation of the diesel, both of which are the real issues.
Old 09-27-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
K1vsk has right except that No. 1 Diesel contains a small amount of kerosene. No. 2 Diesel is the more common grade. Kerosene will improve cold weather starts as well as cold flow (gel temperature). Kerosene also has a lower energy value so your hp will be slightly reduced. It won't affect fuel stability or biological growth.
There are biocides (Racor makes a good one) as well as products to aid with water absorbtion which should be used for this purpose.
Old 09-27-2007
camaraderie's Avatar
moderate?
You have it backwards K1...but the principle is correct. #2 is preferable in boats due to the lubricating properties but in cold weather a bit of kero can improve the viscosity but risks the high pressure pump due to reduced viscosity...ya takes yer chances doing it. Myself...I assume that if I need to add kerosene to my diesel...the boat should be on land and i should be somewhere else warm and snug!! (g) K1 is right about no effect on storing or keeping diesel from degradation
Old 09-27-2007
Valiente's Avatar
When I had a siphon break issue, water got into the block and I had to do kerosene flushes into the empty oil sump with brief (10 second) runs to cycle the water-attracting kerosene. While it makes a poor lubricant, it did the trick.
I might try to throw a bottle in each tank for over the winter.
Old 09-27-2007
I had a 50/50 chance of getting it correct - figures...
Old 09-27-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
#1 Diesel is more refined and has a higher cetane rating. It is usually used in city buses to cut down on pollution and in severe cold weather ops. It is less lubricating and increases wear in the pumps and injectors. Kerosene is even more refined and used mostly as jet fuel. Adding it to #2 diesel will thin it and promote the characteristics of #1 diesel.
Old 09-28-2007
HatterasJack's Avatar
Live to Sail
HatterasJack is on a distinguished road
I mix Kero with my VW diesel engine every winter as well as add a little cetane never have a problem with starting or fuel gel. Seems to hurt fuel milage though, 5 % or more per tank. Only has 300,000 miles on it , burns no oil and still full of pep. Always used Synthetic oil either Amsoil or Shell Rotella Synthetic. Never used it in the yanmar because we are on the hard when it gets cold. Jack
Old 09-28-2007
wescarroll is on a distinguished road
does to burn oil
Oil is what you use for fuel. Might not burn lubricating oil though
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 02:22 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
