09-27-2007
If the PO only put oil on it a "couple of times", you're probably in luck. IMHO oil is a waste of time & money, but there are probably those who swear by it. On both our Sabres, the interiors were unfinished, so we finished the interior with Minwax Satin wipe on poly. We only used high gloss on trim because high gloss tends to show every imperfection. Our interiors now glow and are so much easier to keep clean.
On our current boat, there was 24 years of accumulated dirt in high traffic areas so we needed to clean the wood and get the dirt and oil off first. I used a green 3M abrasive pad soaked in acetone. I rubbed the teak with the grain and the acetone acted as a cleaner and the pad was mildly abrasive. Be very careful with the acetone because it will tend to drip all over the place (put a plastic tablecloth or tarp on the floor). If you don't use the acetone, the oil in the teak or the old finish will probably cause the new poly to fail to adhere or dry.
After the acetone cleaning, there will probably be swirls on the wood. Don't worry. Use 220 grit sandpaper to clean it up. This can be done with a random orbit sander or by hand. You don't need to sand heavily.
Apply the finish with a rag. The first couple of coats won't look great, but by the third you should see good results. Apply at least 4 coats (6 is better). Try all this on a small obscure area first to test for adhesion and suitability. Due to the amount of interior teak, I refinished in sections (head, V Berth, Galley, etc.). This approach was more manageable and didn't take the boat out of commission for a long period of time.
Good luck - it's worth it.
Sabre 38 "Victoria"
