09-28-2007
Originally Posted by SuzieWong
Furthermore I want to receive Wx fax through the ICOM M802 onto my laptop. Is it possible to hook up the PC through a cable (eg: serial 9pin port of ICOM M802 to USB port of PC)? Can I even buy a USB mouse with built in GPS, get the position through computer to the radio?
Who is running the ICOM M802 with or without pactor modem to give me advice?
I don't feel comfortable answering all of your questions, though I do have ideas about some of them, because you sound like you want concrete answers that you can count on not theories.
Can you hook the radio to your PC with a serial cable ? Yes. If you have a USB/serial converter you can hook it to the USB port too, it'll show up as a serial port on the computer. Whether your software lets you select that port or not, I don't know, but it should.
Can you buy a USB GPS device ? Yes, but I don't know if it will support the version you are looking for, and I don't even know if it matters. You can also get regular serial port GPS devices and again use a serial/USB converter to convert them over to USB, that is what I do with my garmin 17. The various bluetooth devices show up as serial ports on your laptop, but again it depends on whether your software will let you select it from a menu or something, but it should allow that.
Sorry I couldn't be more helpful.
