Like Tree2Likes
Old 09-28-2007
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
New lifelines - DIY or pro?
Hi all,
I need to replace my lifelines and I generally prefer to do my own work. However, as I might have six people hanging on one lifeline at the same time, I do not want to take a shortcut.
So, do the hand swaging tools work effectively for what is undoubtedly a critical component or am I better off having these done professionally?
Thanks!
-Jason
Old 09-28-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
DIY, I think a long handled swaging tool works fine when I used it - or look into simply using double braid like I just finished on my boat.
A plus side is that the rope lifelines ended up looking more squared away and if you wanted you can get colors!
Robert
I reject your reality and substitute my own.
Old 09-28-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
There was a recent discussion here of using low modulus line as an alternative to cable.
Old 09-28-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
The stainless steel wire is fairly cheap. But have you checked out the prices on the connecting fittings ?
S/V Scheherazade
Old 09-28-2007
YOu don't really need a swaging tool. You could do much of it with Norseman or StaLok type fittings... and they're reusable. You can also use a Spectra or Dyneema based line for the life-lines...and they're much softer on the hands.
BTW, you really shouldn't have people hanging on the lifelines... they're not really designed to take that kind of load...and either are the stanchions generally. IMHO, lifelines are really more a reminder to help keep you on board rather than anything seriously effective at keeping you on-board. Most are only 24" high, which really isn't sufficiently high to keep you aboard IMHO.
L124C likes this.
Old 09-28-2007
rhaley is on a distinguished road
FWIW, I believe the six people Jason is referring to will be rail meat while he is racing, so 24" works well when you are sitting down on the rail!
Old 09-28-2007
If they're anything like the human ballast I've seen, they're each 180-200 lbs... and I generally wouldn't recommend having 1200 lbs. of people leaning against the lifelines... but that's just me. Of course, if he's recently re-done the lifeline stanchions, and used a serious backing plate on each...it might be fine.
Old 09-28-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
You could always replace 'em with teak . . .
True Blue . . .
sold the Nauticat
Old 09-28-2007
TB-
You got way too much wood on your boat.. you must spend a month a year varnishing the sucker.... even using Cetol as a short cut.
Old 09-28-2007
TrueBlue's Avatar
Señor Member
Nope SD - it takes me about 2 hours per year to coat everything after a light scuff with a ScotchBrite pad. One annual maintenance coat of Cetol Clear is all it needs . . don't even have to bluetape anymore since it goes on so easy.
True Blue . . .
sold the Nauticat
Offshore Log: Check Your Lifelines, Save Your Life PracticalSailor Gear and Maintenance Articles 3 04-26-2007 12:23 PM
DIY running rigging question.... blueranger Gear & Maintenance 15 03-27-2007 07:30 PM
Inspecting and Replacing Lifelines Sue & Larry Gear and Maintenance Articles 0 05-03-2002 08:00 PM
