Old 09-28-2007
Irrationally Exuberant
arf145 is on a distinguished road
Current cockpit area gas grills
OK, that other thread was old (looked like 2003 mainly), but I am interested in the current good, bad, and ugly of gas grills for the stern rail on our 28 footer. We would usually be cooking for four.
Which ones stay lit in a breeeze? Do the current ones still let your dogs roll into the drink? Do you take the propane cannister home with you to avoid storing on board?
Thanks all.
Tom
Old 09-28-2007
I have a Magma Newport Grill. I'm generally cooking for four and if I had to do it again, I would probably get the Catalina model, which is a good deal larger. I leave the 1 lb. canister attached to the grill, but will be making a tank locker that will mount to a cockpit rail out of PVC pipe.
Old 09-28-2007
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
This year I bought a Force 10 Stow N Go, it's nothing fancy and not really big. Enough room for 8 dogs, 2 small pizzas or a plate of nachos. However, it's light and has always stayed lit in a breeze, even 20k winds. I use the small stubby bottles and keep it on all the time. Works for me and the crew hasn't complained yet.
Old 09-28-2007
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
The "log style" force 10 sucked...sold it.
Old 09-28-2007
Caribbean Surveyor
Yep, that's what I had as well. Never stayed lit.
Old 09-28-2007
Abysmally Stupid
jorgenl is on a distinguished road
magma newport, works great!
I would have considered a magma catalina but suspect it would have looked a bit large on my 30' boat...
Old 09-28-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Strange as it may sound, I've been using the same, standard size Magma propane grill with the last three boats - since 1992, and like the Eveready Bunny - it's still going.
It's the model with ceramic briquettes and a burner grate - which I replaced once as well as the Sunbrella cover, but aside from that - no malfunctions at all. Works very well and cooks hot even in high winds. I modified the regulator knob with a clamp to hold down for increased gas flow.
I have an extended hose to the pair of 10# cylinders in their dedicated ABYS locker - but it's sometimes a hassle to rig up.
So, mostly use the small disposable bottles and always remove it from the regulator when not in use - since traces of gas are emitted. The portable bottles are also stored in a shelf alongside the big boys in the built-in locker.
True Blue . . .
sold the Nauticat
Old 09-28-2007
norsearayder is on a distinguished road
old magna still going on 4thboat since 1987 stays lit u have to rebuild gas valve etc every so often
Old 09-28-2007
RealityCheck's Avatar
RealityCheck is on a distinguished road
I see several boats with the deck BBQ connected to the main tank locker. I'm told they are connected to the #2 tank. One owner indicated he had installed a cutoff valve like the cabin stove has but others say they use it like a home style BBQ grill and direct connect.
Since the Locker is vented, and the BBQ is above board and unless at dock would have any fumes passing to the rear of the boat... why do so many people, including manufactures try to get everyone to use the small bottles which are expensive and often hard to find... and are a pain to dispose of??
I've never seen a direct adapter, all seem to be special made when the primary tanks are use.
Old 09-28-2007
stevemac00 is on a distinguished road
Recommend Dickenson Marine for Grills. See their website or Defender.
Grilles are made for disposable propane cannisters (lowest common denominator). That is high pressure (no regulator). If you connect to propane tank you probably want to connect behind the regulator (low pressure) so you'll need a different valve at the grill.
I changed my plans going to Honduras velero General Discussion (sailing related) 11 11-03-2006 11:05 AM
Using Tidal Current Tables Jim Sexton Seamanship Articles 0 01-27-2004 07:00 PM
Using Tidal Current Tables Jim Sexton Gear and Maintenance Articles 0 01-27-2004 07:00 PM
Understanding Tidal Currents Jim Sexton Seamanship Articles 0 08-05-2003 08:00 PM
Understanding Tidal Currents Jim Sexton Her Sailnet Articles 0 08-05-2003 08:00 PM
