10-01-2007
moderate?
Does the Racor look like this:
 with a spin off oil filter type cartridge...or like this:
 with an unscrew T handle at the top?
In the first case...you close your fuel line, unscrew the old filter and put back on a new filter after cleaning the clear bowl out and filling the new filter with diesel and replacing the rubber gasket.
In the second case, you close fuel line, unscrew the top, remove the internal palstic filter element and put things back together while topping up the cylinder with diesel.
The big "risk" for either of these 5 minute procedures is that air gets into your fuel line and will you will need to bleed your engine system to get the air out. This is not difficult and it is explained in the manual I linked to earlier...but it is nice to have someone show you how to do it the first time.
