10-02-2007
If the rod has corroded, it will have expanded in size, since Iron Oxide, or rust, take up more volume than steel or iron does. If that is the case, you're going to have to remove the rod and replace it before the dagger board will work properly. The rod sounds like it acts as a guide for the dagger board.
