10-02-2007
You should be able to repair that fairly easily by having them make a reinforcing sleeve for that section of the mast, and then riveting the reinforcing sleeve over the mast.
Possible damage to other parts of the rig or where the mast steps on the deck are issues, and you'll probably want a rigger or surveyor to take a look to make sure that the hole is the only real damage.
