Old 10-02-2007
freddie5255 is on a distinguished road
Traveler and deck pictures
Hi I have been given a 1973 newport 30 this boat needs serious help and i need pictures of the traveler, winches, and other deck rigging. The stinger (her name) was under 3 feet of water for quite some time so everything needs replaced. ant and all help will be greatly appreciated
Thank you
fred
Old 10-02-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Fred, It may/will cost you more to bring this boat back, rather then buy another boat of the same age.
S/V Scheherazade
Old 10-02-2007
I'd have to agree with Freesail...if this boat was underwater for a while, the electrical system will have to be completely re-done...and many other things, like the cabin interior, upholstery, and interior bulkheads will probably need replacing as well...
Old 10-02-2007
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
Try yachtworld.com for pictures. There are several 1970's era Newport 30's listed with pictures.
Yes, it may well cost you more than the boat is worth to bring it back to life. But on the other hand, if you carefully/slowly assess and survey the boat prior to beginning any work, you should be able to determine if it's worth restoring. Don't underestimate your the value of your own time and efforts and the reality of just how much time a project will take. Also, be advised that you'll gain a lot of invaluable knowledge from such a project as well.
Old 10-02-2007
camaraderie's Avatar
moderate?
This link may be helpful:
http://www.headsail.com/newport_pages/newport_pages.cfm
or this:
http://www.newport30.org/
Old 10-02-2007
Gene T's Avatar
Gene T is on a distinguished road
You will find pictures here
http://capitalyachts.info/
Old 10-04-2007
thanks to all of you i think i may be able to restore her for less than 5,000 is this resonable of course that is withut the engine i plan on installing a outboard the mast and some sails r ok
Fred
I will keep u posted
Old 10-04-2007
blt2ski's Avatar
If you can restore here for 5G, you will make about 10G for your labor, assuming you are doing the work.
You may want to look at the links above, then look at a Harken catalog and see what appears to be stock or equal and rehardware accordingly.
marty
Old 10-04-2007
Gene T's Avatar
You would need to do some searching but there was a N30 that went up on the beach near San Francisco this summer. Sad case of a death on board and the sailors abandoning the boat out of grief. Odd case, but the boat was salvaged so the parts are probably available.
The Perfect Traveler Sam Boyle Racing Articles 0 05-12-2004 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
