Old 10-02-2007
Stu R
stuffinbox is on a distinguished road
Where should siphon breaks be fitted?
The exhaust hose on a used boat I'm looking at runs out through the stern through-hull about a foot above the waterline. The hose runs from the stern about 8 feet inboard and mostly below the waterline to the rest of the raw-water exhaust system. I was pretty surprised that there's no siphon break here. Is this safe? Or do siphons breaks only need to be fitted on below-the-waterline through-hulls?
Thanks
- Stu
Old 10-02-2007
southerncross31 is on a distinguished road
On my boat the hose is looped about 1-1/2 to 2 feet above the thruhull so it would be very hard for a siphon to form.
Old 10-03-2007
billangiep's Avatar
billangiep is on a distinguished road
Thumbs up
From Good Old Boat..... http://www.boatus.com/goodoldboat/Marine_exhaust.asp
Old 10-03-2007
k1vsk will become famous soon enough
One foot above the static waterline is often underwater on heel so a siphon can easily occur. The exhaust should be looped sufficient to ensure the top of the loop, at which point the siphon break should be, is above the waterline under any condition.
Old 10-03-2007
camaraderie's Avatar
moderate?
You don't need a siphon break in the exhaust line. BUT you should run a large loop as far above the water line as is practical to avoid flooding from following seas. You DO need a siphon break in your water injection line attached to the exhaust elbow.
Old 10-03-2007
Valiente's Avatar
I suffered from a sticky plunger and spring in my break, which was otherwise to spec. It convinced me that a bulletproof method would be simply to clamp a length of hose onto where the plunger and vent device was, and to run that up to deck level or better. It's on this winter's to do list.
Developing: Boater missing after sailboat breaks free - WVEC.com (subscription) NewsReader News Feeds 0 06-06-2007 09:15 AM
Exhaust anti siphon jackytdunaway Gear & Maintenance 12 06-04-2007 05:51 PM
Sailboat Breaks Apart, Sinks In Newport Harbor - CBS 2 NewsReader News Feeds 0 04-18-2007 09:15 PM
Siphon break question graham1 Gear & Maintenance 2 11-12-2003 06:13 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
