Blogs
User Name
Old 10-04-2007
CharlieCobra's Avatar
CharlieCobra CharlieCobra is offline
Mama, where's my gun?
CharlieCobra has a spectacular aura aboutCharlieCobra has a spectacular aura about
Perkins 4-108M 50HP overheating.
1994 engine. It ran fine until yesterday and then seemed to be running hot, smelled it too after a while. It never shut down or anything but the gauge read hot. Any particular thing I should check first? I've got a manual and shop manual but haven't had a chance to look at them yet.
Old 10-04-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Check the raw water strainer first... then check the raw water impeller...
If you're new to the Sailnet Forums... please read this POST.
Old 10-04-2007
dougyoung dougyoung is offline
dougyoung is on a distinguished road
If the impeller has any broken vanes. Disassemble your heat exchanger and see if the broken pieces are restricting raw water flow.
Old 10-04-2007
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Señor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
If the strainer and pump impeller both look OK, check the exterior grate over the through-hull raw water intake for sea growth, or other water flow retrictions.
True Blue . . .
sold the Nauticat
Old 10-04-2007
Thanks guys. The water up here is awful dammed cold to be checking things out on the hull.
Old 10-04-2007
TrueBlue's Avatar
Señor Member
Is the seacock all the way open?
True Blue . . .
sold the Nauticat
Old 10-04-2007
I don't know yet. This just started yesterday after a few days of running the engine with no issues.
Old 10-04-2007
ehmanta's Avatar
ehmanta ehmanta is offline
Sailing Junkie
ehmanta is on a distinguished road
C.C.
There are so many things that could cause this: low engine coolant, restricted raw water flow, clogged raw water strainer, oil-cooler, running at max RPM's, impeller issues, calcium build up in heat exchanger, clogged exhaust elbow, etc...
Start from the easiest and work towards more difficult. How long had you been motoring? Was this a sudden over-heat issue or was it slowly running hottter and hotter?
Old 10-05-2007
It was sudden, from one day to the next.
Old 10-05-2007
btrayfors btrayfors is offline
btrayfors will become famous soon enough
"It was sudden, from one day to the next."
Clogged water input or loss of coolant. Check obstructions in raw water inlet...strainer, seacock, etc. Then, check impeller. If you haven't changed it this season, do so. If there are missing rubber parts, they may be downstream somewhere, and clogging the heat exchanger, water jackets, etc. Check coolant level and be sure to use 50% antifreeze/50% water solution.
Lots of other possibilities, as mentioned, but a clogged or damaged coolant system seems most likely for a SUDDEN change in cooling performance.
Bill
Display Modes
vB code is On
50 HP Perkins Overheating Problem Freedom777 Gear & Maintenance 2 07-26-2006 06:28 PM
Overheating Perkins 4-108 Eleanna Gear & Maintenance 13 07-24-2006 06:59 AM
Perkins 4-108 overheating nelsonsmoody Gear & Maintenance 10 06-27-2006 03:24 PM
Perkins 4.108 overheating singingdrum Gear & Maintenance 2 04-22-2003 07:19 AM
perkins 4-108 overheating lisevp Gear & Maintenance 1 01-29-2003 01:38 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
