If the motors are essentially the same then get the smaller one.
It will work less and last longer.
Actually the reverse is true, the more horsepower the motor has the less it will have to do to move the same boat the same speed. The more HP motor will be using less of its reserve capacity.
I disagree.
All the bearing surfaces and working parts will be under less strain all the time.
No, because the motor will be working harder to do the same thing, like more rpm to get the same speed. Anyway who cares? This was supposed to be what are the differances and I showed the differances.
