10-07-2007
One way to do it is to use a router, to cut out most of the balsa, and then finish up with chisels and scrapers. I would highly recommend you do it from the top down, not the inside out, since gravity will work for you, not against you, and you'll have more room and better ventilation and lighting. YMMV.
