B&G Hydra II Speedo - SailNet Community
Blogs
Old 10-06-2007
bils is on a distinguished road
B&G Hydra II Speedo
Anyone have any suggestions on where I might find a thru hull with rotating fin for a speedo for an old B&G Hydra II. The impeller spins sideways and looks like a propeller. I have an electronics guru searching though his dealership so far with no luck. Otherwise I have to drill them out and replace.
Old 10-06-2007
SanderO is an unknown quantity at this point
Good lick. I hoarded a bunch and parted with one to a fella on the West Coast. I'm holding on to the remaining ones. Are they no longer made?
You can replace the transducer with B&G and they are not too expensive actually. They are interchangeable.
jef
sv shiva
Old 10-06-2007
Jeff,
they are no longer made. These old transducers are too smaller than todays versions (including B&G) and have to be drilled or replaced with exact same ones. I need the whole thruhull component. Not just the impeller.
Thanks for the thought though.
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
