Water tank replacement options - Page 2 - SailNet Community
post #11 of 13 Old 10-08-2007
Cruising
RandyonR3's Avatar
Bladders
I know they get a bad rap but I've got a series of 50 gal Plastimo tanks in my boat. The origional tanks were bladders, on my FIRST 42. the boat was designed for all-out racing so the bladders made perfect sence, but this racer has turned cruiser and the tanks were replaced. I found the easiest and least expensive was the Plastimo Bladders. They are probably the easiest to install as you just roll them out and fill them up, and they settle into the boats contour.
I havent really worried about how clean they are as I'm one of the most picky people when it comes to water in my tanks.. Nothing goes into the tanks that hasnt been run through a series of filters including a carbon 5 micron.
I have to as my watermaker (spectra) has a clean water electronic flush where every 90 hours, it flushes the system with tank water. If I had any type of crud in the tanks, including bleach, or clorine, I'd destroy my system.
You might want to check them out..the price is right.......
RandyonR3 is offline
post #12 of 13 Old 10-08-2007
Freesail99's Avatar
Practical sailor did a report on bladder tanks in this months issue.
S/V Scheherazade
Freesail99 is offline
post #13 of 13 Old 10-08-2007 Thread Starter
Valiente's Avatar
That's probably coming tomorrow. They did an interesting article on "best diesel tank material", but that's not the current question.
Valiente is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 09:10 PM
Patching water tank? geary126 Gear & Maintenance 10 01-03-2008 07:19 PM
water tank buildup smaconf@msn.com Hunter 2 11-30-2007 09:51 AM
Why have a gray water tank? haukebo Gear & Maintenance 7 11-09-2006 10:26 PM
