Old 10-07-2007
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
Move to Texas. You can sail and not worry about frozen . . . anything . . . accept maybe adult beverages.
Bob T
"I cannot not sail" - E. B. White
  #12
Old 10-07-2007
It may not be enough to burst a hose, but it might be enough to damage a seacock. Just because the damage is relatively minor, doesn't mean it won't sink the boat with little warning come spring time.
Originally Posted by Freesail99 View Post
I can not conceive of any boat making enough condensation within a hose to make it burst from freezing. It isn't going to happen.
  #13
Old 10-07-2007
k1vsk will become famous soon enough
Still not sure how leaving it in really makes a difference in the amount of condensation which could form unless you leave the system charged throughout the winter which is an impracticality. Arguably, a partially full system (which is what you get by simply filling the lines) provides more water vapor to condense without significantly lowering the volume of free space available compared with an essentaily emply system. The engineer in me working over-the-top here...
Even if condensation formed, it would be insufficient to fill the lines to the point that freezing could damage anything.
Guess I have too much free time.
  #14
Old 10-07-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
[QUOTE=sailingdog;203397]It may not be enough to burst a hose, but it might be enough to damage a seacock. Just because the damage is relatively minor, doesn't mean it won't sink the boat with little warning come spring time.QUOTE]
If it is cold enough to freeze there is a 90% chance that the boat isn't even in the water. In New Jersey that number is maybe 99% chance of the boat not being wintered in the water. If the boat is in the water in the winter, it is most likely being lived on and heated. So there should be no chance of sinking a boat. In addiction I still have a hard time conceiving of even a 2 ft hose filling with enough condensation to burst a hose or a seacock.
S/V Scheherazade
  #15
Old 10-07-2007
Originally Posted by retclt View Post
Move to Texas. You can sail and not worry about frozen . . . anything . . ..
been there....
  #16
Old 10-07-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
wellll....if all else fails, read what it says on the container...I'm sure it mentions whether to leave it in or not.
  #17
Old 10-07-2007
Not always obvious if the container directions are written by engineers or lawyers - the distinction can be important.
Given this stuff expands as temp decreases, it occurs to me a full system can be more problemmatic for that reason alone
  #18
Old 10-07-2007
SENIOR CHIEF
....huh???????????????????
  #19
Old 10-07-2007
SENIOR CHIEF
Originally Posted by DrB View Post
Winterizing the boat yesterday. Drained the water tanks and poured the Pink Anti-Freze in and pumped through the lines. What's the general consensus in leaving the stuff in the lines versus pumping it out of the lines and closing everything up and leaving the lines essentially unfilled except for residual pink anti-freeze?
DrB
Google: Fresh Water Antifreeze/Potable water antifreeze/Marine & RV antifreeze..etc. lots of info...
  #20
Old 10-07-2007
apparently something I said?
can you be a little more specific
You may post attachments
You may edit your posts
Liveaborders that never leave the slip? I don't get it. Help! Lancer28 Living Aboard 47 10-10-2007 01:50 PM
Parts for sink drain overholtzer S2 1 09-07-2007 04:07 PM
How/what to winterize for living aboard in Great Lakes duffer1960 Living Aboard 14 10-17-2006 02:46 PM
SEO by vBSEO 3.6.1
