10-09-2007
Checked the MSDS for four different brands of antifreeze, and none have Ethanol as an ingredient. I don't know what brand you're using or where you got your information, but I believe it is wrong.
Originally Posted by DrB
The alcohol in vodka is ethanol (ethyl alcohol). The Pink Anti-freeze has ethanol in it also. If the Pink Stuff works and doesn't harm seals, vodka won't harm seals also. However, Vodka is a lot more expensive/gallon than the Pink stuff.
DrB
