Old 10-07-2007
equitiman is on a distinguished road
Changing rig type
Okay...I'm not sure if this is a really stupid question but I'm going to ask it anyway...
Is it possible to change a boat from a bermudian rig to a gaff rig? Does a given boats design characteristics limit its use only to the type of rig the designer had in mind? If this is possible...what issues would I face. Would my mast be too tall? Is it difficult and/or expensive to find a gaff? Would I need to completely redo all of my running rigging? I need to replace my sails and just had this crazy thought.
I don't want to start a discussion about the pros and cons of gaff vs. bermudian rigs!!! I just want to know about the feasibility of changing from one to the other!
Thanks...and if it is a stupid question don't be afraid to let me know. Also, if it matters I have a 19' daysailer.
Bob
Old 10-07-2007
Gaff rigs are generally lower aspect ratio and generally have a longer boom... so your mast would probably be too tall for the boat rigged as a gaff-rig. You would probably need to modify your running rigging, since you'd need a halyard for the gaff. This would also add weight aloft... which may make the boat more tender. Another problem I see is the backstay, if your boat has one, would probably interfere with the gaff on tacks and gybes.
Old 10-07-2007
Yes its stupid
Old 10-07-2007
Tartan34C will become famous soon enough
A rig and hull are part of a package. The shape of the hull is a little different then you would find in a gaff rigged boat compared to a jib headed one. That doesn’t mean you can’t make the change if by some chance the hull is suitable but the change will require a new mast and standing rigging not to mention the changes to the chainplates because the standing rigging is different. All in all it would be a big change and usually not worth the money.
All the best,
Robert Gainer
Old 10-07-2007
Here .. Pull this
Sailormann will become famous soon enough
Yes
Not necessarily limit, but the center of effort on a gaff is generally a bit further aft than on a bermudan rig, so the boat will tend to have more weather helm, which you can compensate for by adding a bowsprit.
Probably
I think you would probably need to get one made.
You'll need to add a topping lift, halyard, and reposition/remove your vang at the very least. You'll also need to determine how to attach the gaff to the mast - track or rings. Your sails will need to be cut and finished to accomodate the necessary fittings.
It would be better to sell the boat and buy a gaff-rigged one. You will find it very difficult to resell the boat if you alter it this way.
Old 10-07-2007
Valiente's Avatar
Unless the boat is a "classic" and was once in fact gaff-rigged and you are restoring it to original, this is a waste of time and money.
Old 10-08-2007
Okay...so...like many things it is technically possible but completely impractical! Well it was just a crazy thought and I figured that it wasn't feasible anyway so I'm not too disappointed. Thanks for your answers.
Bob
Old 10-08-2007
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
Go for it!
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 10-08-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
PSC Flicka are found with both rigs, but the gaff is fairly rare. I don't know the specs for both rigs on that particular boat, but I can imagine there are differences in mast height and boom length. I've seen WW Potters change to a lateen rig, so I guess anything is possible. Also, it would be much less expensive to change the rig of your 19', than a large boat. If you're going to do it, take time to really work out the job or you'll end up looking like a floating gypsy wagon.
Dictated, but not read.
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 01:19 AM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 02:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
