10-08-2007
Hello,
How was the pump supposed to work?
I have mine set up so that I can turn it on / off with a switch, AND there is a separate float switch that will turn the pump on if the water reaches a certain level.
For that set up you need to have two power lines run to the pump - a switched power line for the switch, and another power line that is always powered on for the float switch.
You can buy a float switch at any marine store.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
