Drying Wet Deck Core with Acetone - Page 2 - SailNet Community
post #11 of 12 Old 10-08-2007
RAGTIMEDON's Avatar
Drying time depends upon ambient humidity, temperature, and air flow. Consequently there is no answer to "How much time will be required to dry it?" Your wife probably has a clothes dryer in the laundry room. Notice that it uses heat (either gas or electricity} an forced air flow (a fan and a vent.) Same thing works for drying that wet deck. It will dry a lot faster if you can force air in or suck air out of the holes you drill in the deck, and apply a heat source such as an infrared lamp, hair dryer, radiant heat room heater, or some such. But if the relative humidity where your are working is high, that will slow it. After the area appears to be completely dry, give it another 20percent excess treatment. I know that is not the answer you wanted, but it's the facts!
RAGTIMEDON is offline
post #12 of 12 Old 10-08-2007
saurav-
There is no real way to estimate the drying time, without knowing a lot more information as RTD has pointed out.
The other question is how much of the existing core has rotted or delaminated?
sailingdog is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
