Old 10-08-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Coolant Intake, Weeds and Strainers
We have a 1976 Pearson 30 with a venerable old Atomic A4. It's running fine and I'd like to keep it that way. Problem is: Due to way above-average temps, below-average rainfall, lots of wind from the south, our canal being oriented mostly north/south, and us being at the north end: We're in the middle of an incredible weed patch.
At least one visiting boat this weekend overheated attempting to navigate that weed patch.
Our coolant intake is on port side of the center-line, just forward of the engine. Comes up into a right-angle elbow, hose then leads aft a few inches off the hull and, near as I can tell, then goes up and over the back of the engine, into the top somewhere on the starboard side.
We currently have no strainer on the coolant line. I don't recall seeing one of those strainer type through-hulls when the boat was hauled for the survey. (Doesn't mean it isn't there--I just don't recall seeing it. I think I'd remember it, tho.) I'm certainly not getting in that mucky, nasty canal to find out.
I'm afraid to start/run the engine in that mess.
I think I'd like to install a strainer, at least. But I'm not sure I have the room/space, given the way the coolant line runs.
Suggestions? Pictures?
It occurred to me to try to poll her in/out past the weed patch, but my guess is the bottom's too soft for too deep for our boat hooks to accomplish that.
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-08-2007
You could always scull the boat past the weed patch. You'd need a fairly long oar to do so though.
Old 10-08-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
Do yourself a favor with a winter project and install a nice basket strainer. You get alot of piece of mind for only a little over one boat buck. It beats clogging seagrass into the cooling passages of your engine.
Dictated, but not read.
Old 10-08-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
I have a small strainer on the raw water inlet. Model 5411 universal diesel. It's about 20 cm long, 15 cm dia. It has a perforated metal strainer inside. It's clear, so I can see if there's any stuff in it. It looks much like the inage in the link posted above. I've never picked anything up, but it gives me peace of mind.
Old 10-08-2007
SEMIJim's Avatar
Don't think that hasn't already occurred. Or kedging our way in and out.
Sculling isn't as insane as you might think. Our freeboard isn't all that excessive. Abracadabra sits fairly low in the water, compared to some of her more recently-produced counterparts.
We need to find some solution. There are only three weekends left until haul-out. I'll be damned if she's gonna sit in the slip because of a weed patch.
Of course: The immediate problem would be solved if we'd just get a decent amount of rain and some northerly winds for a few days.
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-08-2007
Hmm.. be careful what you wish for, but I'll speak to my personal weather goddess for you.
Jim
Old 10-08-2007
Cruisingdad's Avatar
Best Looking Moderator
Ditto... and with your problem, the larger the better. Put a scupper on teh outside too.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 10-08-2007
SEMIJim's Avatar
Yeah, there's a downside to too much wind out of the north (besides the fact it usually means colder, perhaps much colder, weather): Strong enough wind out of the north, for long enough, actually lowers the water level in the canal--which is already gettin' kinda marginal for some of the deeper-draft boats as it is.
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-08-2007
SEMIJim's Avatar
Will do.
Is that one of those thru-hulls that's kind of half-egg-shaped with long slots in it on the under-hull bit?
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-08-2007
SEMIJim's Avatar
Will do.
That one you've pictured looks like a good-sized unit. Where's that one from?
Thanks,
Jim
s/v Abracadabra
1976 Pearson P30
