  #21 (permalink)
Old 10-15-2010
Aurea's Avatar
Cal Sailor
Aurea is on a distinguished road
Need PDF on High Seas Diesel Heater
I noticed Biscay36 had sent a PDF manual to Daneasysailing.
Would it be possible to get this PDF?
I just bought one of these heaters and it seems to work but I could
definetly use the manual before Install it.
Any help would be great!
Thanks
  #22 (permalink)
Old 12-29-2010
ARIMAII is on a distinguished road
Aurea
It's 25 Degrees Here In North Florida! I Was Just Given A Hi-seas
Heater In Pieces. It's Model 100c. If Possible Could I Get In Line For A Manual Also? The Posts Are Very Informative Regarding Troubleshooting.
There Was No Pump With The Unit. Does Anyone Have More Detail On The "facet" Pump As A Replacement? Is Fuel Metering Dealt With At The Valve Assy.? Can A Gravity Feed Day Tank Be Used?
If Anyone Can Forward A Manual Many Thanks:
Happy New Year!
  #23 (permalink)
Old 12-29-2010
Aurea's Avatar
Cal Sailor
Thier are no new parts for High Seas but these guys have parts that will work
DickinsonMarine.com - Propane Fireplaces
O and gravity tanks still need a pulse pump or heat will end after ten mins or so.
  #24 (permalink)
Old 12-29-2010
Hi-seas Heater
Thanks For The Dickenson Parts Info. I'm Interested In The "pulse" Detail Of The Pump. Is There A Chance Of Copies Of The Manual Still Being Available?
  #25 (permalink)
Old 01-03-2011
brob76 is on a distinguished road
Any chance I could get a copy of the manual by email? I just picked up one of these units and it would be great to know how it works before installing.
brober29 at gmail dot com
  #26 (permalink)
Old 02-28-2011
Intens is on a distinguished road
Hi-Seas, also in the Netherlands
Hello Charlie,
A reply from the other side of the big water.
I also have the type C100-8 aboard and looked up for some more information of this outstanding heater. I did some maintenance in 2009 (just cleaning) and replace the firepit(!?) with a special glassfibre. It was original asbestos.
I am very interested in a copy of that manual you mentioned!
Any chance to e-mail this manual?
I would appreciate that.
I just scanned a Dutch written manual into a pdf.
If anyone is interested (and able to read), I will send it.
With regards
Ron van Wijngaarden
Hi Seas Heating Corporation / Diesel Heater-hi-seas-diesel-heater-c100-8.jpg
  #27 (permalink)
Old 04-28-2011
wars2 is on a distinguished road
manual for Hi-Seas diesel htr model 100
Originally Posted by Biscay36 View Post
Hi Dan,
I have a PDF copy of the Hi-Seas manual plus a few diagrams that came with the yacht.
I am not a frequent user of the sailnet forum, so perhaps you could advise on the easiest means of forwarding on this document to you.
I can send by email, but that assumes that you wish to share your emial address.
Just let me know.
Thanks.
Charlie.
Charlie .. any chance I too could get a copy of that Hi-Seas heater manual from you? Just bought the used heater THEN found out how hard it is to find parts as well as the manual.
Thanks so much.
Sheila (wars2)
  #28 (permalink)
Old 04-28-2011
deniseO30's Avatar
Lies about her age
Gentlemen.. the key component in diesel heaters like Dickinson Sigmar and others is the "oil metering valve" or carburetor, such heaters with valves like this have been around a very very long time."gravity" feed or low pressure pump just get the fuel to the metering valve.. The use of stainless steel jackets and flues make them marine type heaters. You may remember a heater that worked the same way when you went to your grandads hunting cabin!
Fuel oil needs high temps, atomization, wick, plate, pan, or basket type burner, which is heated by the flame so much it glows and acts like a catalytic converter.
So..when the needle valve is coked up.. the flow diminishes,,, the oil delivered is not enough to get the burner section hot enough to cause complete combustion.. SOOT! Learn how to clean the metering valve often.. it's the key to happy heating and sootless combustion. use of kero may help but it will still eventually coke up
here's a rendition of a new heater with the same old type of combustion your boat heaters use. Flame GLT-I
Does this look similar? http://www.rural-energy.com/publicat...cument-244.pdf
ck out this! [IMG][/IMG]
  #29 (permalink)
Old 08-15-2011
sailor/surveyor
amazon43 is on a distinguished road
Is there any chance of getting a PDF copy of Hi Seas diesel heater manual? I certainly would appreciate it.
Alison
Diesel Heater Carboning SV_WholeHeart Living Aboard 8 10-27-2011 07:43 PM
Seas Marine Heating Corporation MichaelGrant Gear & Maintenance 0 10-08-2007 02:29 PM
Diesel Heater/Home Heating Oil wind_magic Gear & Maintenance 12 07-31-2007 09:02 AM
Diesel heater for water heating SteveCox Gear & Maintenance 1 12-13-2006 10:01 AM
installing duct system for diesel heater and air conditioner levenezia Gear & Maintenance 1 09-25-2004 03:20 AM
