Propane leak - SailNet Community
Blogs
Old 10-09-2007
Sea Slacker
brak is on a distinguished road
Propane leak
So, I finally installed my brand new propane system, with alarms, solenoids and all. And the first pressure test reveals a slow leak.
I took the entire system apart, testing shorter pieces until I am left with just a tank, a pigtail hose and a regulator (plugged on the other end). The leak is still there. So, I bought a new pigtail and a new regulator - and changed over and resealed all the connections - same result.
Anyone dealt with that before? Could it be the tank itself? How the hell do i find it? Soap and water failed miserably, perhaps because the leak is very slow (I get down from 175psi to 120psi or so in 24 hours). Ideas would be very welcome.
Old 10-09-2007
Try a different tank. If you still have the leak, chances are that it isn't the tank. BTW, what kind of connections are you using. IMHO, you should be using propane hose with swaged fittings.
Old 10-09-2007
Sea Slacker
at this point I am using Xintex (spelling?) regulator and their pigtail hose. That is it, everything else was disconnected and removed, so it just does not matter.
Trying a different tank may be the thing to do except that properly sized tank is a long mail order away (only one kind of tank fits my propane locker). Oh well, guess there is no way out of that.
Old 10-09-2007
Here .. Pull this
Sailormann will become famous soon enough
Yes.
Also - make sure that you are using real propane fittings with the flared ends and "O" rings. The "Expert" I purchased some things from this year thought he would save me some money and sold me some journeyman stuff which did not work properly. Irritating. I don't skimp on my boat. Don't recommend others do either.
Old 10-09-2007
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
This is NOT a small leak. With a pressure drop like that there have to be bubbles in a soapy water test. Try submersing the entire tank in a bucket of water. If it is the tank you will see bubbles.
Old 10-09-2007
RickLaPaz's Avatar
RickLaPaz is on a distinguished road
The soap test should always work--it takes zilch to puff up a bubble. Grab some Dove, water a bristle brush and some beers and sit a spell. One fitting at a time.
Caution: This may entail a six pack or so---your drinking may vary........
Old 10-09-2007
Sea Slacker
most fittings are flare type, but some have to be pipe thread by necessity. those regulators they sell have a threaded 3/8" hole in the bottom without any specific sealing method recommended, and the only way it can be closed is by using pipe thread fitting (and special gas pipe compound, I suppose, at least thats what I got). Same goes for a solenoid - it has a flared fitting on one end but a regular NPT female on the other. This is the stuff those boating gas companies sell, in fact none of their own parts fit together without lots of connectors. Irritating.
Old 10-09-2007
Sea Slacker
I thought about that, but it is a steel tank (and also it is pretty darn big - I don't have a bucket big enough for it). May be a tub would work?
Old 10-09-2007
RickLaPaz's Avatar
Bath tub, maybe. But do you guys have the larger residential trash cans on wheels? That's what I use for my outboard testing........
Old 10-09-2007
Here .. Pull this
You submerge your outboard in a big garbage can ??? Uhmm - not sure how to say this - but if you didn't "test" it so often you might find it runs with fewer problems.
You're welcome - always happy to help
Propane Cabin Heater Mysun Gear & Maintenance 9 06-08-2009 12:29 AM
Wondering about where to put propane sensors... Sailormann Gear & Maintenance 5 05-15-2007 12:58 AM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 09:00 PM
Fire on Board! Don Casey Seamanship Articles 0 07-14-2003 09:00 PM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
