Old 10-09-2007
L124C's Avatar
L124C is on a distinguished road
Old winch handle replacement
I have a couple of Lewmar 8 winches for the halyards on my boat. The spline on the handle is a 8 point star pattern, similar to current handles, though slightly smaller. The previous owner was using a handle with a square spline, which was filed slightly to fit the winch at 4 points in the star pattern. While I wasn't happy with this make shift approach, it worked. The other day I managed to drop that handle in the bay ! I clearly foresaw the event, and have been searching for a replacement handle for a while without success. The winches work well, and I hardly want to replace them for want of a handle. Anyone know where I can find a replacement. At this point, I would even be happy to find a square spline handle!
Old 10-10-2007
mt7555 is on a distinguished road
Thumbs up New design plastic OneTouch Handle
Try a Dax OneTouch handle - This is a new design with a quick release bar running along the top of the handle. You just grab it and it releases. No more thumb release! You can check it out at - just do a search for "DAX Onetouch Handle".
This is the plastic version of the design - Lewmar has licensed the design and makes the metal version. I prefer the plastic version - Nice balance and lighter. I have raced with this handle this year and it is real nice to use and exceptionally strong!
Old 10-10-2007
MT7555-
You missed his point entirely... his winches use the older, smaller eight-point opening, not the standard one found on modern winches. The Dax OneTouch won't do him any good—it is too big to fit.
L124C-
Your best bet is to contact a used yatch equipment supplier or consignment shop, like Minney's Yatch Surplus. They're likely to have what you need. Get two.
Old 10-10-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Hane you checked westmarine.com?
Old 10-10-2007
SENIOR CHIEF
Here's one that floats!!http://cgi.ebay.com/ebaymotors/8-FLO...QQcmdZViewItem
Old 10-10-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Practicing a MOB for the floating winch handle may be a good idea, or what's the point in getting it ?
S/V Scheherazade
Old 10-10-2007
SENIOR CHIEF
Some older handles here:http://motors.search.ebay.com/winch_...0QQsacatZ31281
Try to come up with some sort of measurement to go by...
Old 10-10-2007
SENIOR CHIEF
Measurement for instance: I have a square drive handle that fits a 13/16 socket perfectly.
Old 10-10-2007
I believe the older winches used a 5/8" or 3/4" drive rather than the newer 13/16" drive
Old 10-10-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Somebody at our club mentioned that not long ago. He allowed as how non-floating winch handles were a better way to go because if one goes over the side in a race, there's no agonizing over whether to lose time fetching it
Jim
s/v Abracadabra
1976 Pearson P30
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Gear and Maintenance Articles 0 10-05-2000 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Racing Articles 0 10-05-2000 08:00 PM
