Paddle bits for drilling decks - SailNet Community
post #1 of 4 Old 04-03-2002 Thread Starter
I''m in the process of bedding new vhf and masthead light hardware. Have removed the old and let the damp plywood core dry thoroughly. Also have removed about 1/4 to 1/2 inch of rotted wood around the circumference of the hole. Will be filling hole with epoxy and letting dry thoroughly prior to redrilling. I read that to drill a hole of 3/4 inches should be done with a ''paddle'' bit as opposed to a ''spade'' bit, but I''ve been unable to find any information
about them. Any ideas on finding a paddle bit and / or doing the work described above?
Thanks all.
Curt
BallastBoy is offline
post #2 of 4 Old 04-04-2002
Are they not the same? I am guessing that what is being advised is to use a spade/paddle bit that has "spurs" that scribe the outside of the hole leaving a smoother hole finish.
thomsonjd is offline
post #3 of 4 Old 04-04-2002 Thread Starter
I''m getting the impression they are one and the same. The article I read was ''Drilling and Filling Holes in Your Boat'' by Sue & Larry. Here''s the partial quote: ". If your hole needs to be larger than a half inch,...you should consider using either a hole saw or a paddle bit." I searched numerous commercial drill bit supply houses online and nowhere was a ''paddle bit'' to be found. I have a good carbide ''spade bit'' at home, so I''ll use that and should be good to go.
Thanks for the feedback.
Curt
post #4 of 4 Old 04-07-2002
Paddle and spade bits are the same esentually. you might consider a hole saw as you might run into difficulty trying to cut thru epoxy and filler with a paddle bit.
Ole Pete
Peter_pan is offline
Non-skid decks mrputzo Gear & Maintenance 8 10-08-2001 03:49 AM
