10-11-2007
Tom-
based on your photos, it looks like the stanchion base on the port side may be the cause of the leak on that side. On the starboard side, it is probably one of the screws for the hatch.
I would add a backer block to shroud and use a longer bolt. Also use a fender washer if the the backer block is not metal.
