10-11-2007
I don't recommend this technique for anything larger than about a square foot in size. The epoxy is heavier and doesn't add as much strength as properly rebuilding the laminate by re-coring it would. IMHO, if the core is rotted to any degree, you're much better off re-coring the deck in that area—rather than doing a bubble-gum and baling wire repair.
Originally Posted by Freesail99
If you drill the 1/4 hole you can use a Alan key ( spelling ? ) in a drill on a very slow speed to widen up the inside of the hole without making the 1/4 hole any larger. The short end of the Alan key would be going into the hole. By doing this, you increase the volume of the inside of the hole, allowing more epoxy to be added to the hole and increasing it's strength.
