10-11-2007
No one has ever done it before...  they all magically step themselves.
BTW, are you doing this by hand or are you going to have access to a crane? If using a crane, then you will probably want to sling the mast just above the mid-point or so. If doing this with an A-frame, you can often use one of the halyards, usually the spinnaker, to go to the top of the A-frame and then use a block and tackle, like the main sheet or a boom vang, to raise the a-frame. This assumes you can pin the base of the mast to the mast step on the deck so that it acts like a hinge.
