10-15-2007
Hitchin' a ride
Well, if you're on a port tack and the water in your cockpit is down on the starboard side, but the drain goes up to the port side, seems to be counter productive, doesn't it? Its not going to flow uphill very easily. Not sure what the standard is, but maybe some sort of check valve would be a better way to keep the back flow out? If it doesn't inhibit the flow out.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
