10-15-2007
Another Propane Question
We have on board a Dickinson P12000 propane heater.
We had it installed when we first purchased the boat.
It has never given us any trouble and has been great for keeping the main salon nice and cozy on a chilly spring are fall weekend.
We love it. It has always worked great.
This past weekend it was necessary to operate it.
It would lite fine, but after about an hour or so, the flame would slowly die out to nothing. My tank was filled recently, so I am sure I had plenty of fuel.
I would turn off the gas valve, wait a few minutes, than turn the gas valve back on, and relight it. Again it would burn and put out heat for a time than slowly die out.
I thought perhaps that it was not getting oxygen.
The flue is two pieces. An outer chamber brings air in from the outside to prevent depleting the oxygen from inside the cabin, while the inner lining exhausts. I took the flue apart to see if it had a blockage and found none.
We went to bed Saturday night a little disappointed. The next day Sunday, I was making breakfast on the stove. While I was cooking the flame slowly started to dissipate.
Now I checked the tank and switched over to a brand new filled tank and I got the same results.
I checked the fittings in the locker with the soap and water test and found no leaks. There is pressure in the system according to the pressure gauge on the tank. There is no smell of propane anywhere in the cabin (I don't think there are any leaks).
I am a bit puzzled, but my next thoughts are to check
a) The regulator and
b) The solenoid
I don't think it would the solenoid because I would think that it would be either open or closed. Not slowly closing or part way open. That doesn't make sense to me.
Both the heater and stove worked fine, than the flames slowly die out.
Not on one minute than off the next, and there does not appear to be any propane leaks. (If we had a leak, I don't think I would be typing this right now, I lit and re-lit both appliances lots of times.)
What does the panel think?
Could I have a bad regulator?
A bad solenoid?
What should I check next?
Courtney is My Hero
