11-14-2007
Last Grumpy Old Sailor
Originally Posted by drynoc
Thanks, guys. The breaker you suggested came in and I began the installation. However, if I understand the drawings that came with it correctly, both the source and the user green ground lines should connect to the grounding point on this breaker, which is tiny. I don't see a way to connect them both at that point. Should I splice one into the other? What am I missing?
I don't know the "marine" way to do this, but in house wiring what one would do is make a short "pig tail," connect the two other wires and the pig tail together, then the other end of the pig tail to the common point. Connecting the two other wires and the pig tail together would be done with a plain ol' wire nut (properly sized).
Jim
s/v Abracadabra
1976 Pearson P30
