Blogs
User Name
  #31 (permalink)
Old 10-18-2007
wumhenry wumhenry is offline
wumhenry is on a distinguished road
Originally Posted by soul searcher View Post
I would think that if the problem were in your cutless bearings that when you are docking the boat and go into reverse with a little headway on that you would hear the same or close to the same sound.
just a thought
I don't. One more reason for looking elsewhere.
  #32 (permalink)
Old 10-18-2007
deniseO30 deniseO30 is offline
Denise, Bristol PA,
deniseO30 is on a distinguished road
silly question.. have you checked the transmission for lubricant?
Denise, Bristol PA, Oday 30
  #33 (permalink)
Old 10-18-2007
timebandit timebandit is offline
timebandit is on a distinguished road
Here we go---
Engine sounds normal------eliminated.
Engine mounts would make a clunk sound when shifting into gear under all conditions----eliminated.
Transmission under the same load in smooth and choppy water-----eliminated.
Transmission mounts would make a clunk when shifting in gear under all conditions----eliminated.
Drive shaft and bearings work the same in smooth and choppy waters-----eliminated.
Some kind of thrust bearing going bad should make noise all under all conditions in forward gear---eliminated.
Might try reverse in choppy water---would unload the thrust bearing.
You say the prop is ok and tight-----eliminated.
I doubt the hull is flexing and causing this noise or you would have noticed it before.
Still there is still one thing that might make a Clatter noise and is connected to the transom.
The exhaust system might have a loose clamp some where and is banging against something..
-----and the professor was killed in the parlor with the candle stick-----
Please let us know when you find out.
  #34 (permalink)
Old 10-19-2007
Question
Not since the beginning of the season. I'll have a look next time I go aboard.
Do you think a shortage of lube could cause a noise that's heard only when motoring in a chop?
  #35 (permalink)
Old 10-19-2007
Question
Originally Posted by timebandit View Post
Here we go---
I said that the prop isn't fouled, but I haven't checked to see whether it's tight. If it were loose, could that cause the noise that I've described when the boat is motoring in a heavy chop and without causing it when the boat is motoring in flat water?
  #36 (permalink)
Old 10-19-2007
Question
'Nother hypothesis: could the noise be caused by the zinc rubbing against the cutlass bearing due to hull flexing or a loose coupling?
  #37 (permalink)
Old 10-20-2007
Assuming all the tests have been made with the exception of---
Reversing in choppy water.
A diver to check underwater stuff (prop-zinc-other).
We cannot dismiss the power train and move elsewhere.
Problems like these are a mechanics nightmare.
The ones that begin with "It only happens when---"
Oops!
I have forgotten two very important questions that should have been the FIRST ONES.
Is this boat new to you??
Have you motored under these conditions and had this problem, or is this the first time??
  #38 (permalink)
Old 10-22-2007
Oops!
I bought it in July 2006. I got the same funny noise last year when motoring into a heavy chop.
  #39 (permalink)
Old 05-25-2008
Any fix yet?
Display Modes
vB code is On
Remember The Words Of Our Father...Amen USCGRET1990 Off Topic 15 10-09-2007 02:32 AM
bad noise from 4-108 blowntime Gear & Maintenance 1 07-08-2007 10:48 PM
Funny thing about them Hunters.... PBzeer General Discussion (sailing related) 16 11-05-2006 03:14 PM
Growling noise around cutlass , or maybe packing or ???? obiec Gear & Maintenance 6 06-01-2004 01:18 PM
Generator Noise Oxley Gear & Maintenance 0 11-10-2003 08:20 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
