10-16-2007
Originally Posted by nolatom
For the clew line, include a padeye or something on the opposite side of the boom from the cheek block, to tie the bitter end to. Then you get a 2:1 advantage when you run it up through the reefing cringle, then back down through the cheek block, then forward.
Thanks Tom,
I was going to simply tie a bowline around the boom, and then run it up through the reefing cringle, and then back down through the cheek block, etc. What you're saying is that I should install padeye in place of the bowline? I guess I'm not clear on how that would deliver the 2:1 advantage. Thanks again for taking the time.
Sailingfool,
Thanks for the links. I can see how the tack reef assembly is a better approach.
