Old 10-16-2007
erps's Avatar
the pointy end is the bow
Adjusting a Danforth Constellation Compass
I'd like to fine tune the adjustment on my compass and then swing it. The PO kept good records but the documentation for the compass wasn't one of them. Anyone still have their instructions? I see four compensating screws around the base, but thought I'd find out what they do before the trial and error routine I usually find myself in.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 04-05-2011
frostp is on a distinguished road
Same Problem
I see this is an old post... Did you ever find a solution to this? I have the same compass that needs calibration and am not sure the proper procedure with the four adjustment screws...
Thanks..
Old 04-05-2011
I found this:How to Adjust a Marine Compass | eHow.com
Not exactly on point but the general procedure might work. I've had difficulty finding exact information on this too.
A message to Danforth or whomever might work too.
1984 Fast/Nicholson 345
Old 04-05-2011
erps's Avatar
Thanks Ron,
I haven't monkeyed with the compensating screws yet. It's a strange arrangement though. The four screws are attached to rods that all connect to a small metalic block right under the compass. I'm not sure buts the four screws could actually be two rods that pull the metalic block a little bit out of alignment one way or the other. I should just pull the compass off, turn the screws and see how they influence the metalic block, but haven't done it yet.
I haven't tried emailing Danforth yet.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 04-05-2011
mike dryver is on a distinguished road
erps don't play with the adjuster screws unless you know what you are doing. go to Chapman's Piloting and it will tell you how to swing a compass
Old 04-05-2011
erps's Avatar
That's probably good advice Mike, but it goes against my nature.
I've had some experience swinging a compass in previous boats, but I had instructions on those particular compasses for compensating it.
Still, I may just leave it alone and make up a new deviation card, as I've installed a chart plotter on the pedestal guard and I haven't evaluated whether it had an impact on the compass yet.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 04-05-2011
Thanks very much for the info
Old 04-05-2011
I also found this link..
http://www.irbs.com/bowditch/pdf/chapt06.pdf
A bit cerebral
Understanding and Using the Magnetic Compass Jim Sexton Learning to Sail Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Seamanship Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Gear and Maintenance Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Cruising Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Her Sailnet Articles 0 03-01-2000 07:00 PM
