Old 10-17-2007
hertfordnc is on a distinguished road
Another Yanmar 3QM30 question
There are no guages and I did't hear any alarms when I started this engine.
Would it be practical to install a set of automotive oil, temp and amp guages?
If so, where are the pickups.
Old 10-17-2007
Rockter will become famous soon enough
hert...
There really must be an oil pressure switch on the motor somewhere, or at least a port (with ba plug in it right now) that it can be screwed into. It should not be hard to find.
Installing an oil pressure alarm is a matter of tapping in a switch... it's just a wee plug with a spring contact in it.... into the port. If the oil pressure is low, the switch completes the circuit to groud (the motor), and the small current through the switch closes a separate alarm relay, feeding a much larger current to the alarm mounted on the engine room wall, or somewhere convenient.
Even if you just had that, it should be enough. make sure it's LOUD. Mine is a car horn, and a relay from under the bonnet of an old BMW. It works fine, now 15 years on.
I also fitted an oil pressure guage... I just put a wee "T" fitting onto the engine oil port (as described), and fitted the switch to one end, and led the oil pressure to a guage on the other end. The guage was mounted on the engine room wall. Cover the oil line with a bit of spiral hose to protect against chafe. The guage was like £15 ($25 then).
Good luck.
Rockter.
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 08:23 PM
Yanmar 3QM30 hose question hertfordnc Gear & Maintenance 5 10-17-2007 10:01 AM
Smoke on the Water - Yanmar Question DrB Gear & Maintenance 7 09-04-2007 05:31 PM
Yanmar - fuel injection pump question rperret Gear & Maintenance 7 05-24-2007 10:00 AM
