Old 10-17-2007
sailboy21's Avatar
sailboy21 is on a distinguished road
Homebrew Seatalk PC interface
I ran across a website which details building a seatalk to serial port connection, and programming in C to interface with seatalk devices. It seems to makes sense, but I cant seem to "hear" or talk to my autopilot on my laptop. I constructed both the "unidirectional" and "bidirectional seatalk-RS232 interfaces and neither yielded any results.
Has anyone done this before?
BTW, my purpose in doing this project is to use a wireless game controller to control my S1 wheelpilot. I dont want to pay $500 for a remote when I can make my one for $30 .
Here is the website that aided and embedded this attempt to avoid being a good consumer.
www thomasknauf de / seatalk htm
Thanks
Old 10-17-2007
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
They make waterproof game controllers?
Old 10-17-2007
byrondv is on a distinguished road
Fun project - and I am going to have to bookmark that link in the hopes I get around to integrating my laptop with an autopilot.
From your description it sounds like you have having issues w/ the device driver portion of your system. Though it could be anyone of a number of things. I am assuming that you are using the listed C code on the page (and not the Windows version in the *.zip slightly further down). My guess would be that you are running Windows - not a true MS-DOS environment. The hardware abstraction layer in Windows doesn't allow for using ports based on memory-mapped IO (otherwise it would be possible to stomp all over another program's IO).
So, I would first look into your code / OS. Ensure you can at output pins and input pins (a Multimeter can be useful for this - otherwise a paper clip and an LED can work wonders).
Once you get that working - I would ensure that your custom circuit board is translating the data correctly (again - ensure you are getting _something_ in both directions).
If you post some more info (OS, which code you are using, compiler, and where the point of failure is (custom hardware, or custom software)) I could say a bit more.
Good luck!
Seatalk to NEMA Interface Bill225 General Discussion (sailing related) 2 03-21-2006 01:04 PM
Seatalk to NEMA Interface Bill225 Gear & Maintenance 1 04-29-2005 10:33 AM
ACR RapidFix 406 EPIRB with GPS Interface Mark Matthews Seamanship Articles 0 01-24-2000 07:00 PM
ACR RapidFix 406 EPIRB with GPS Interface Mark Matthews Gear and Maintenance Articles 0 01-24-2000 07:00 PM
ACR RapidFix 406 EPIRB with GPS Interface Mark Matthews Cruising Articles 0 01-24-2000 07:00 PM
