Old 10-19-2007
YACHTS33 is on a distinguished road
Question galvanized vs stainless
It seems to me that galvanized steel and galvanized wire would be used more in standing rigging. why not it's stronger than stailess .sure it's not geat to look at. i would love to here what your thoughts on this. maybe we will all have carbon fiber rigging one day. aloha.
Old 10-19-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
You are correct as far as you go. And galvinized rigging is what is used on virtually all cargo ships, at considerable cost savings as well. Esthetics aside, you must consider that the standing rigging is attached to aluminum masts and spreaders. Use of galvinized raises the issue of isolating dissimilar metals to prevent galvanic action or electolysis between the two. That is actually quite a challenge and creates a perpetual maintenance problem. Given the fact that most boats are running around with their original rigging after more than a decade of use, the cost and slightly less strong stainless is considered reasonable.
If your point is; are we too stainless steel fixated, I'd certainly agree with it's use in ground tackle leading the way.
Wm. F. Buckley, Jr.
Old 10-19-2007
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Galvanised anything eventually corrodes and fails in the marine environment when you least expect it, so it is not a good choice for standing rigging.
Galvanised wire halyards used to be common back in the "old days", but nowadays you can use spectra or kevlar which is at least as strong and easier to use.
Carbon fibre rod rigging is standard on the newer racing yachts already.
--Cameron
Old 10-19-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Sailaway, I've never seen this so I can't say for sure but I don't think that the zinc galvanizing would pose a corrosion problem with aluminum. Zinc and aluminum alloys are very close in the galvanic series, certainly closer than Al and SS.
Now with carbon fibre (graphite) and Al, there would be a big potential there and unless the mast is also composite, isolation would have to be used.
There are 10 kinds of people. Those who understand binary and those who don't.
Old 10-19-2007
Hartley18's Avatar
Termite Fodder
If you're going to use composite rigging, it would be pointless not to have a composite mast already - a bit like having icing without the cake.
When money is no object (high level racing), I've seen people remove even boat nails and use velcro instead just to save a few kilos - maybe - on the off chance it may make a difference.
--Cameron
Stainless vs. Galvenized Cable Strengths tagster Gear & Maintenance 14 08-03-2007 12:16 PM
Stainless or Galvanized? capecodphyllis Gear & Maintenance 18 12-12-2006 02:57 AM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
