-   -   Leak Around Exhaust Hose (http://www.sailnet.com/forums/gear-maintenance/37804-leak-around-exhaust-hose.html)
ArgleBargle 10-19-2007 12:12 AM
Hi. I recently discovered a small amount of water in the bilge under the engine. Found a small leak where the exhaust hose fits on the elbow exhaust/raw water exit mixer on my sea water cooled Yanmar 2GM.
I am assuming this is just a case of the hose clamp not being tight enough and plan to fix it assuming as much, but I am rather inexperienced when it comes to these thnings and was wondering: is there something else i should be worried about e.g. is this a symptom of increased back pressure because of some crap further down the exhaust hose?
I have a raw water strainer and normal water flow is seen coming out the exhaust.
thanks in advance
cheers
-ArgleBargle
CapnHand 10-19-2007 12:23 AM
It could be that simple or it could be that the elbow is corroded and has holed through. Different engine in this thread, but shows how far it could go.
Take the hose clamp off and have a look up the pipe, you'll soon see.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
