10-20-2007
Señor Member
I stand by my post!
If you keep up with your teak, as some of you seem to, no chemicals are needed.
But I have seen some green and gray teak from years of neglect. If you want this cleaned, it takes chemicals or some sort of mechanical removal, ie sanding big time. Teak contains alot of oil and is therefore highly resistant to rot. The sun WILL ,however, eat your teaks oil if not protected. After the oil is gone, then the wood starts to go as well. In previous posts, I've been a big promoter of oiling your teak. A good Teak Oil will replenish that which the sun has evaporated/dissolved over time. It's a proven fact, that when the sun beats down on something daily, it will destroy it. This is the reason for car wax, reguardless of clearcoat or whatever. Wax is the sacraficial anode so to speak. The site I gave you to look over had some very good info and a good point of view. I don't know the product nor care who they are. I'm not into promoting anything but what I have experienced. Since retiring from the CG in 90, I have worked at several marinas and come accross teak that was neglected for 30-40 years. I've seen the long term results. I find it disheartening to see Alex's decks so bland and gray, when some teak oil would make them so pretty as well as protected.
I think some of yuns need to come aboard into the 21st century and modify some of your beliefs. My intention is to never post anything biased... controversial maybe...I've not owned many sailboats, I don't think alot of s/netters have either...but by god, I've worked on hundreds of them...
I know my spelling sux, but it's not my fault sailnet doesn't have a spell checker...gimmee a break...
If you don't like my post, then please call 1-800-wha-aaaa...or just bite me
Lighten up Chief - no one's criticizing you personally - just that biased advertisement.
The reason nothing but water should be applied to teak decks is the potentially adverse effectc to the polysulphide caulking. If the caulking degrades, so does the water resistance = leaks through subtrates with cored deck penetrations.
Applying salt water prevents drying across the grain, which creates tension, or stretching of the caulking. Eventually the wood bond is breached. Some pros (I'm not a teak pro - just know what I've read and heard from them) say teak oil may reduce the seam caulking integrity as well.
True Blue . . .
sold the Nauticat
