seacock difficulties - SailNet Community
Blogs
Old 04-07-2002
tappers is on a distinguished road
I''ve just reinstalled a Blake''s seacock, having ground it in to a reasonable finish and applied plenty of silicone grease.
Try as I may I cannot seem to adjust the retaining plate properly. If the handle turns easily, under gentle pressure, the retaining plate seems a bit loose. If I carefully tighten the plate then as soon as it "sets" the handle becomes disproportionately harder to turn.
It beats me. Any ideas?
Thanks.
Tappers
Old 04-30-2002
newuser is on a distinguished road
If I remember correctly, the Blake seacock has a tapered barrel. If so, maybe you need to take it apart and lap the surfaces together using some grinding compound specific for that application (e.g., Spartan) or some fine automotive valve grinding compound from NAPA, etc.
When they are right, they work like a charm.
Keep on sailing,
Ken Coit
CD/14 #538
CD/36 #84 Parfait
Hailing Port: Raleigh, NC
Sailing from: Beaufort, NC
Old 05-01-2002
gnorbury is on a distinguished road
I just fitted 5 new Blakes seacocks to my Nicholson 35 after replacing the old ones which were starting to fall apart after 17 years hard service.
The key question is whether you are seeing any seepage past the conical plug? With mine, the retaining plate is loose enough to wobble with light finger pressure. No water comes in so I am happy...
If you overtighten the plate you will cause undue wear on the cone and eventually the valve will seize up.
Graham
Old 05-09-2002
scottcallahan is on a distinguished road
enough of this fixing and re-fixing it just replace it. it takes me 1-2 hrs to replace a seacock. that includes taking the hoses off seacock off and thru hull out. also
putting in the new one.
enough of this trying to save money on safty equipment.
-scott-
Old 11-08-2006
pompiliud is on a distinguished road
from where can one buy Blake seacocks?
hi:
I live in USA, near DC/Annapolis.
From where can one buy Blake seacocks? Does one have to order them from England? Is there a website for these (and other parts reasonably priced)?
Thanks. PD
Old 11-08-2006
camaraderie's Avatar
moderate?
You just questioned a 4 year old post ...but these guys should be able to help!
Spartan Marine Hardware • 340 Robinhood Road • Georgetown, Maine 04548 - - HOME - Email
207/371-2542 • 800/325-3287 • Fax: 207/371-2024 - SpartanMarine.com -
Old 11-08-2006
I prefer the lower maintenance of the ball-valve seacocks.
Old 11-09-2006
FrankLanger is on a distinguished road
I have been reading about sailboat maintenance lately and am getting conflicting information about ball-valve bronze (not marelon) seacocks. Some books indicate that they don't need any maintenance unless they are becoming noticeably stiff, in which case they should be taken apart, cleaned, greased and reinstalled. Other books indicate they should be taken apart annually to do the above. Do any of you know what is correct; and what most people do?
Thanks,
Frank.
Old 11-09-2006
Generally, all ball-valve seacocks should be operated at least once a month and greased twice a year IMHO.
Old 11-10-2006
svindigo is on a distinguished road
How are you greasing those ball valves if the boat is in the water?
Thx
Ike
boats with easy engine, seacock, sea strainer, etc access night_raver Boat Review and Purchase Forum 3 08-26-2004 11:11 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
