Electronic Winterization? - Page 2 - SailNet Community
post #11 of 13 Old 10-24-2007
guess Raymarine must have read all the prior responses...
k1vsk is offline
post #12 of 13 Old 10-25-2007
Radar Scanner
What about the radar dome/scanner? I have had my Furuno radar for 3 years and removed the display and scanner every winter, and took them home.
I noticed that most boats here in Toronto Canada leave their radar scanner on the boat for the winter. I always thought that was not a good thing but this spring when I reinstalled my radar I found there was a problem with the scanner and took it to the local Furuno dealer for repairs. The dealer couldn't get around to fixing even though he had it for nearly 3 months because he was too busy to look at it so I had no radar the entire summer. Finally I took it back and sent it to Furuno in the US for repairs.
So now I'm thinking maybe it was better to leave the scanner installed on the boat for the winter. Do most boaters, especially in the colder climates, leave their radar scanner on the boat for the winter and if so have you had problems with it after the winter?
phiggins is offline
post #13 of 13 Old 10-25-2007
I would leave the Radome connected, but cover it to prevent water from getting into it. The most common problem with marine electronics is corrosion in the wiring connections. Leaving the radome on the boat and making sure the connection is tight and well coated with some sort of protective grease goes a long way to preventing such problems.
sailingdog is offline
Advanced Electronic Charting Jim Sexton Seamanship Articles 0 12-01-2004 07:00 PM
Advanced Electronic Charting Jim Sexton Gear and Maintenance Articles 0 12-01-2004 07:00 PM
